Hi, I have made a silly goof. I accidently threw my systems folder in the trash and now my macbook will not boot. When I turn it on it flashes an apple and circle with a slash. Any suggestion on how to fix this? I have the latest Tiger OS.
Hi
Do you havs the system disk that came with your MacBook? If so you should place the disk in the drive and then start up holding down the "c" key this will start up using the OS on the cd?dvd. If you hav'nt emptied the trash you can simply open the trash and drag the system folder to your main HD. Then restart it should work
