System bootstrapper has crashed
mik
Single user mode reveals that the above is the problem. How do I get to the screen that shows the two hard drive icons, where one is for
repair. Presently, i can only get to the one hard drive icon. Or is there an even better solution? Thanks!
I you have started up holding the Option key and get the Startup Manager with only Macintosh HD, then you may have a newer version of OS X/macOS that changed the way you access the Recovery Partition.
About macOS Recovery
Try the steps in the lonk above to see if you can access it and let us know.
