SOLVED Spacebar Not Acting As Usual
I used to be able to use the spacebar on my macbook to act as an 'enter' key.
Now, it seems, this no longer works; not sure why.
Anyone have this issue?
(Sierra 10.12.6)
  • Did you have it mapped to use as the enter function?
  • In what application(s) did it work as an enter key?
Thanks - figured it out.
Had to check 'all controls' under 'keyboard shortcuts' - though don't remember having to do this previously.
