I just finished the Currency Converter tutorial, which worked fine, but then I tried to create a simple java application using NSPopUpButtons -- it compiles successfully and the application launches, but no window appears. It is a very simple application with three pop up buttons and two text fields and one button for processing the inputs from the fields, but it doesn't work and there is no hint as to the nature of the problem other than the somewhat cryptic Run Log message:
Conduit Fill has exited with status 0.
[Session started at 2006-08-27 18:22:46 -0700.]
Anyone have any insight as to how I can get the application to display?
Thanks in advance.
Thanks in advance.
