Safari page loading problem.
Help! Whenever Safari navigates away from its homepage it partially loads the page and then quits. Firefox for mac is worst it fails to load and just get the spinning roseta. Done virus scan,cleared cache and reset Safari. Turned off firewall. The other pc works fine sharing same router. Any ideas?
This might help.
"Multiple applications quit unexpectedly or fail to launch:
The following AppleCare® Knowledge Base documents provide some help in troubleshooting instances when a given application quits unexpectedly or fails to launch:
Mac OS X 10.4 Tiger™
"Mac OS X 10.4 Help: My application quit unexpectedly."
"Mac OS X 10.4: Reopening an application after it unexpectedly quits."
Mac OS X 10.3 Panther®
"Mac OS X 10.3 Help: Why did my application unexpectedly quit?"
In addition to the reasons cited in the articles above, we would add the following in cases where multiple applications quit unexpectedly or fail to launch. This FAQ, derived from information in a variety of chapters in our book, Troubleshooting Mac® OS X, can often resolve situations where multiple applications quit unexpectedly or fail to launch. Perform the troubleshooting steps below in the order specified.
Font problems. When multiple applications quit unexpectedly or fail to launch, it is often a font problem.
If you recently installed new fonts, remove them.
If you disabled fonts with Font Book, particularly System fonts, re-enable them. Likewise, if you incorrectly resolved duplicate fonts, you may have disabled key fonts. Follow the instructions in our "Undoing Font Book" FAQ to resolve any issues that may have been caused by using Font Book incorrectly.
Certain fonts have been known to be problematic with Mac OS X, specifically Helvetica Fractions and Times Phonetic. If these fonts are installed, use Font Book to disable them. See the AppleCare® Knowledge Base document from the following list corresponding to the version of Mac OS X you are using for instructions on disabling fonts in Font Book:
Tiger: "Font Book 2.0 Help: Turning fonts off."
Panther: "Mac OS X 10.3 Help: Turning a font off or on."
Some HP® printer software installs a corrupt Times RO font that can affect Mail, Safari, Software Update, and possibly other applications There are several AppleCare Knowledge Base documents about this problem, the most illustrative being "Mac OS X: Software Update unexpectedly quits when an update has a license agreement."
Corrupted fonts:
Mac OS X 10.4 Tiger introduced a feature in Font Book to check for damaged fonts. See the AppleCare Knowledge Base document "Font Book 2.0 Help: Checking for damaged fonts."
Morrison SoftDesign Font Doctor™ is an excellent utility for finding and often repairing corrupted fonts.
Corrupted fonts can also be individually identified by process of elimination. This can be a tedious process which involves removing fonts one-at-a-time until all corrupted fonts are identified. Details can be found in the "Fonts" chapter of Troubleshooting Mac OS X.
Disk, permission, or cache corruption. Run the Procedure specified in our "Resolving Disk, Permission, and Cache Corruption" FAQ. Perform the steps therein in the order specified.
Incompatible Startup Items, Login Items, interface modifications or menu extras. See our "Troubleshooting Startup and Login Items" FAQ.
Corrupted preferences other than those of the affected applications. Check preferences system-wide using the freeware application Preferential Treatment.
Insufficient RAM or free disk space. See our "Problems from insufficient RAM and free hard disk space" FAQ.
Downgrade installations of Mac OS X.
If you perform an Archive and Install of Mac OS X and do not use Software Update to reinstall the same version of Mac OS X you were using, multiple applications can be affected. See "Applications don't work after reinstalling Mac OS X."
For the proper procedure to perform an Archive and Install, see our "General advice on performing an Archive and Install" FAQ.
Programming errors. Bugs in application code are not uncommon. For third-party applications, check the vendor's Web site for updates to the application, reports of known bugs, or for information on how to contact the vendor for support.
Corrupted application.
See our "Uninstalling Applications" FAQ for general advice on uninstalling applications.
For third-party applications, uninstall, then reinstall the problematic application following the uninstall instructions provided in the application's documentation.
While it is rare that one needs to reinstall applications bundled with Mac OS X, one can:
Trash the problematic application.
Reinstall it from your Mac OS X Install Discs using the using the shareware application Pacifist. Pacifist has excellent documentation, so you should have no problems with it.
Reapply the last Mac OS X Combo Update corresponding to the version of Mac OS X you are using. This will pick up any changes related to this application which were made since the application was originally published on the Mac OS X Install Discs.
Other software problems or conflicts. Console can often provide for clues for additional troubleshooting. See our "Checking Console for clues" FAQ.
Corrupted Mac OS X installation. Perform an Archive and Install of Mac OS X using the instructions in our "General advice on performing an Archive and Install" FAQ.
Hardware problems. Run the Apple Hardware Test that came with your Mac. See our FAQ "The Apple Hardware Test" for details on using this important troubleshooting tool."
