Running eDraw with a parallel?
I am new to using a mac and also new to posting for help on a forum. I need to access a program called edraw (downloadable online with a free version), which lists that it is able to used "with a parallel" on the Mac. Does someone know what this means/how I would make this happen?
Any help is appreciated! Thank you!
Jess
The edraw software can only run with the Windows OS. On a Mac, there are a couple of ways to run Windows software, but all such methods require an "applicable' version of Windows be installed also. The 3 pieces of software one can use are:
1. Apple's Bootcamp.
2. A program called "Parallels".
3. A program called VMware Fusion.
It takes time and effort to set up your Mac to run such software.
