Problem in Mail program
When I try to change the preferences in the Mail Program in System 10.4, I get the following message:
Writing your preferences to disk has failed. Your preferences may not have been saved. The permissions on ~/Library/Preferences may be wrong or your disk may be full.
I know the disk is not full. Where exactly do I find ~/Library/Preferences, and how do I rectify the problem? Has anyone else had this problem? Does anyone know what to do about it?
Thank you to anyone who can enlighten me.
Charles Relle
You might want to revise your note and remove your email address. Spammers tend to lurk public forums and harvest email addresses.
As for your issue, try this. Go to your Applications folder > Utilities > Disk Utility and run the option to repair permissions. See if that helps.
SOLVED Problem with apple mail on macbook pro 13
Mail Problems 1
Mail problem 3
Mail problem. 8
Mac Mail password problem 6
Mac Mail Problem 2
Ipad mini 2 email problem 1
Mail Problem - OS 10.6.8 - Exchange Server 1
