Problem between color sync and adobe
Thj
hi, any tips on how to fix these error codes? have deleted and re-entered ios. problem between color sync and adobe
  • Which model Mac?
  • Which version of OS X/macOS?
  • Which version of the Adobe application(s)?
  • Can you list the ColorSync errors you are getting?
Thj
OK, thanks.
OK, thanks.
If you are trying to email a ColorSync Profile or Adobe PS file that is too large for an attachemnt, maybe try uploading it to iCloud Drive/Dropbox/Google Drive and share it that way?
How large is the file? Many email providers have a file size limit for attachments.
Thj
If you can send me your e-mail, i can sendt photo on error color sync
