Left Click acts as Right click!
Ok first i do not use the Mighty mouse or whatever its called. Second is i have used 2 mouses and the same problem keeps on occurring. The problem is that sometimes when i left click it acts as right a right click. It is extremely annoying and i need help By the way the mouse i am using right now is a razor naga so i doubt its the nagas fault, also i used a Logitech mouse before and the same problem occurred. I need help quickly.
If you are not using a Mighty Mouse, go to your User>Library>Preferences and drag the mouse .plist to the desktop and reboot.
I would also reset the PRAM.
also have a look in System Prefs > Mouse to see what settings are configured there for left/right clicking
