Help!
I,ve instaled a new hard drive on my macbook, and now when I try to install Mac OS X 10.4.6 it starts fine but it doesn't give me any options on the menu when I have to choose a destination to install it in... Any idea why ?
Hi there and welcome !
Silly question first...have you rechecked the connections...if you swap back in the old drive does it see it ?
What make and model is the new drive ?
thank you! I've sorted it... the new drive wasn't formated yet, so I had to create a new partition with the disc utility, creating a volume to install OS X...
Hi ssanta-marta, welcome to the forums :)
Glad you sorted it out and thanks for letting us know how you did it. It helps in case someone else is searching for an answer to a similar issue ;)
