Hi All
Lots of help needed please.
Am needing to compile a feedback form for people with literacy problems. Instead of asking them to write anything I have decided to use a smiley face system ie going from to I can't find what I want (only need them in black and white) so decided to make them myself. Which program should I use to do this? Have tried just using Pages. Although I have drawn the face using autoshapes I can't seem to be able to select the whole face and copy it. Whenever I try this all the shapes are copied but when you paste the shapes are pasted in a line and I have to move them again to create another face
I know there is probably an easier way to do this but I need help to find it.
Many thanks
Ria
Many thanks
Ria
