Help! I have no idea what this means and what I should do to fix it
Anonymous UUID: DA3F3101-2156-DA2F-ACD7-C809BC0A7792
Mon Nov 23 10:23:11 2015
*** Panic Report ***
panic(cpu 1 caller 0xffffff800159ed64): launchd exited (signal 9, exit status 0 CS_KILLED)
uuid info:
0x7fff6e678000 uuid = <03673b53-b8b7-34d1-adce-f449e78e39cc>
0x101637000 uuid = <13d08717-b23a-38be-85a6-085b051f8322>
Thread 4 crashed
RAX: 0x0000000000000000, RBX: 0x00007fff6e6b75f8, RCX: 0x0000000101637a00, RDX: 0x000000010167e790
RSP: 0x0000700000116750, RBP: 0x00007000001167d0, RSI: 0x00000000000001b1, RDI: 0x00007fff6e6b75f8
R8: 0x00007fff8e941119, R9: 0x0000700000116b40, R10: 0x00000000000ca000, R11: 0x0000000101676170
R12: 0x0000000000000000, R13: 0x0000000000000000, R14: 0x0000000000000000, R15: 0x000000010167c839
RFL: 0x0000000000010246, RIP: 0x00007fff6e6922e0, CS: 0x000000000000002b, SS: 0x0000000000000023
Thread 0: 0xffffff800c880490
0x00007fff97ca1d85
0x0000000000000000
Thread 1: 0xffffff800ca01b60
Could not read LR from frame at 0x0000700000199d48
Thread 2: 0xffffff800ca016d0
0x00007fff97cb07b4
0x0000000000000000
Thread 3: 0xffffff800da00490
0x00007fff97cac674
0x00007fff97ca0a3b
0x00007fff97ca11b8
0x00007fff97ca76bf
0x00007fff97c9fd0b
0x00007fff97c9fab8
0x00007fff8fe614f2
0x00007fff8fe5f375
0x0000000000000000
Thread 4: 0xffffff800ea18db0
0x00007fff6e67c063
0x00007fff8e941262
0x0000000101676170
0x0000000101663c72
0x00007fff97c9c3c3
0x00007fff97cac674
0x00007fff97ca0a3b
0x00007fff97ca11b8
0x00007fff97ca76bf
0x00007fff97c9fd0b
0x00007fff97c9fab8
0x00007fff8fe614f2
0x00007fff8fe5f375
0x0000000000000000
Thread 5: 0xffffff8010080000
Mac OS version: 15B42
Kernel version: Darwin Kernel Version 15.0.0: Sat Sep 19 15:53:46 PDT 2015; root:xnu-3247.10.11~1/RELEASE_X86_64
Kernel UUID: AB5FC1B4-12E7-311E-8E6F-9023985D8C1D
System model name: MacBookPro9,2 (Mac-6F01561E16C75D06)
Model: MacBookPro9,2, BootROM MBP91.00D3.B0C, 2 processors, Intel Core i5, 2.5 GHz, 4 GB, SMC 2.2f44
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333235533643465238432D50422020
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333235533643465238432D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xF5), Broadcom BCM43xx 1.0 (7.21.94.29.1a4)
Bluetooth: Version 4.4.2f1 16391, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE HDD ST500LM012, 500.11 GB
Serial ATA Device: MATSHITADVD-R UJ-8A8
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: Hub
USB Device: Apple Internal Keyboard / Trackpad
USB Device: IR Receiver
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
USB Device: USB 3.0 Bus
Thunderbolt Bus: MacBook Pro, Apple Inc., 25.1
**My computer randomly restarts constantly. It just started happening randomly the last two weeks. I don't know what's causing this or how I can fix it. Any help would be great. Thank you!
You are experiencing a kernel panic. It can be caused by many things: corrupt software, failing had drive, failing RAM, video card issues, etc. From the log, it looks like you are running OS X 10.11.1 El Capitan on a MacBook Pro (13-inch, Mid 2012).
-Have you been experiencing any hangs/freezing before this issue?
-What peripherals are plugged into it?
-Have you installed any software recently?
-Do you have any anti-virus or third-party apps like MacKeeper or CleanMyMac installed?
-Has the Mac been dropped or any liquid spilled on it, especially while it was powered on?
Thanks for responding!
I just downloaded El Capitan a few weeks ago. My puppy also chewed my old laptop charger, so I've been using the other charger (the square plug charger) that can go charge instead. I downloaded Bit Defender virus protector, which I've ran and it says no issues. I got rid of Spotify because I thought this was the issue (my girlfriend started having a similar problem on her computer). I've also installed Kindle Kid's Book Creator program by Amazon/Kindle.
Would it be any of these programs? Thanks so much!
No worries, that's why we are here.
t could actually be Bitdefender Antivirus for Mac...especially if it is a recent install and it runs a full-time active scanning routine. You could try totally uninstalling it and see if the issue clears up.
Spotify can cause slowness, but shouldn't cause panics. The Kindle app should be fine, as it is not a utility or app that is always running in the background.
Also, make sure you have a decent amount of free space on your hard dive - at least 20-30GBs.
Ah, thank you! I'll try uninstalling it completely. I'll also check my memory. Thanks so much for your help!!!
