hi ..
the second way I will tell you is not a good but you can do it ..
1- try to repair the windows by reinstalling it and put an admin PW while installation ( repair not new install ).
or
2- from mac interface open the XP HD and copy your important doc. then delete the partition and re install it again ( you need to install full system and all your exe )
that is all
