HELP !! (hard drive)
I have WD hard drive that the Mac can't write on it, I tried to re-format it so I can do write in Mac however I forgot to back-up so I interrupted the erasing so quickly but now when I plug the Hard drive to any computer it can't read it.
This is the utility log, it may help anyone experienced with this:
2012-08-26 02:38:37 -0500: Disk Utility started.
2012-08-26 02:40:23 -0500: Preparing to erase : “AHMED”
2012-08-26 02:40:23 -0500: Partition Scheme: Master Boot Record
2012-08-26 02:40:23 -0500: 1 volume will be created
2012-08-26 02:40:23 -0500: Name : “AHMED”
2012-08-26 02:40:23 -0500: Size : 1 TB
2012-08-26 02:40:23 -0500: File system : MS-DOS (FAT)
2012-08-26 02:40:25 -0500: Unmounting disk
2012-08-26 02:40:31 -0500: Creating the partition map
2012-08-26 02:40:31 -0500: Disk Erase failed with the error:
POSIX reports: The operation couldn’t be completed. Device not configured
2012-08-26 02:40:31 -0500: Erase complete.
-Is there a specific reason your are using a PC formatting scheme - Master Boot Record with MS-DOS FAT file system?
-Do you have all the files you need off of the WD?
-Are you going to use this HD with the Mac only?
-Have you tried the partition option instead of erase?
I'd say the data is now unrecoverable. You need to be able to mount the drive to get at the data.
My Macbook can't read my external hard drive, i was using mac fuse. however the trial period has expired so I decided to format the whole external drive instead of buying macfuse.
No, I didn't backup I need the files =(
No i will use it with both Mac and microsoft but I will do anything to get my files even if I won't be able to use it on Microsoft.
No i didn't, I was going to erase and re-format the whole drive.
I have pulled out the drive after 3 or 4 seconds of the erasing command, I think most of the files still there, but I don't know how to get them back as no computer can read the drive !!
