Hard drive capacity
Hi Ric,:)
I installed a new hard drive, a 200gb seagate barracuda at 7200rpm. (external firewire)
I formatted it with mac os extended (journaled).
I can't capture video with final cut pro into the new hard drive.
So I tried to verify the drive but it shows error and ask to repair.
It also show error after I press the repair button.
After reformatting again with mac os extended (journaled) it works.:D
I checked the drive capacity, there were 2 icons.
One show at 183gb. Prolific pl350 (manufacturer of ext. firewire)
and the other, hard drive name show at only 127gb.
Why is there a drastic drop in capacity ??
:confused::confused:
Thanks Ric
Hi there !
An external Firewire drive 'should not' be affected by the128GB limit on your machine, this is only on drives on the ata internal bus...
Can you give a screen grab of what you are seeing in Disk Utility ?
Have you bought a prebuilt external drive or an enclosure and fitted the drive yourself, what make and model please ?
Ric.
Hi Ric,
Thanks for the reply, :)
Actually I forgot to tell you that I did tried put in the drive via ata in the system
when I have problem capturing with final cut pro, to confirm whether the ext.
firewire causing the problem. I think that cause it to reconise only at 128gb.
even when I make it external again, It still show at 127gb. That a stupid
mistake I did :eek: . Can I get maximum capacity if I reformat again via firewire ??
Thanks again Ric, sorry for the trouble.
It should work give it a go, it's no trouble !
Try and format (repartition) as a Firewire Disk.
What Make and Model "Enclosure" have you got ? Some older chipsets have the 128GB limit !
let us know how you get on !
Hi Ric,
I reformat my hard drive as a firewire. Now i got it at 186gb.
In the disk utility>erase, volume format: I use mac os extended (journaled)
Name: untitled, I checked the Install mac os9 disk driver box.
In the security option, I checked the zero out data box. Approx. 14gb lost.
Is it because I checked the box install mac os9 disk driver ? or is it normal ?
My drive is seagate 200gb barracuda 7200rpm and encloser is Gizmo a
combo usb-2 and firewire. One more thing, can I delete data in the trash
folder in mac ? How? I 'm still new to mac. Thanks Ric.
With out getting to technical...that's correct 14GB lost, on my 100GB PowerBook Drive I have 93.04GB out of 100Gb Disk...
Yes delete the trash, do it every day other wise it builds up ! JUst check there's nothing in there that you don't want !
