- Dec 19, 2020
Hi all,
I'm running a 2014 macbook pro with some Intel dual core (2.6GHz i believe).
The machine recently got some issues that it would, for example, just randomly reboot a lot of times or that the sound drivers didn't work until i reset P&V Ram.
Now I turned it on, it worked briefly, then shut off / went to sleep. No matter what I do, I can only get one response from it: holding any key results in the waking up sound playing, periodically with some delay between.
The same goes for holding the power button, when i try to force it to shut down. Battery is fully charged.
Does anybody have ideas on how I can attempt solving this?
Thank you all!
Edit: I updated to the latest version of MacOS from a few days ago. I believe there has been an update after which I didn't install yet, but I'm not sure.
Thank you all!
