9.2.2 laser printer compatibility
Message in a bottle: Anyone know a solid laser printer that's compatible with OS 9.2.2? I'm getting mixed signals from OEMs. Seems like after 9.2 the number of compatible printers falls off....Matt
Hi Matt,
welcome !
What are your requirements ? Black and White, Colour, Postscript ?
let is know and we'll have look...
Ric...thanks...looking for a B/W printer (for mom, who's 78). I'm not familiar with all details of her system, except 9.2.2 is the OS...memory shouldn't be a problem...can you respond based on this data alone?
Matt
Ok,
does it have to be a "Laser Printer" or can it be a inkjet ?
Ric....really looking for a monochrome laser printer. Had miserable luck with inkjet - unless you know of a good one.
Best regards,
Matt
Hi Matt,
not sure where your based...this is a UK supplier, but I'm sure you will be able to find a local one to you !
Looks pretty good...Epson Printer.
I had the same requirements.
I use a Samsung ML-2855 laser printer with OS 9.2.2
According to Samsung, it is even compatible with 8.6.
It is the only dedicated laser printer that I found that works with the best operating system ever created.
There are some all-in-one machines, but this is a real monochrome laser printer.
