(3) Networked MACS not communicating correctly...
Hi you guys!
I am having a problem with (3) of my Macs not communicating correctly so I can transfer files between them.
I have prepared a few attachment to illustrate my issue below.
(2) Mac Pro's with El Capitan and Mojave OS. And (1) MacBook Pro with Ventura OS.
Note: All 3 computers should be showing ALL 3 computers under Locations on each drive to be able to access them.
Please view my screen shots below and we can go from there.
Thank you for your time!
Reesche
Hi Reesche,
1st thing that I would do is on each computer go to the System Prefs -> Sharing and instead of screen Sharing, turn on Remote Management. Set it as Only allow these users, and make sure that your user name is listed. Next click the Option button and check every option there.
Next on each computer go to Network under the Go menu of the Finder and make sure that all of the computers are discoverable.
This will give you the option of mounting the Drives in a computer remotely as well as being able to do screen sharing between the computers.
