- Sep 25, 2015
So I loaded up a SanDisk Ultra USB stick with some stuff, using my M1 iMac on Monterey. Plugged that stick into older Macs (El Capitan), and NO ICON SHOWS UP ON THEIR DESKTOPS. Yes, Finder is set to allow that to happen. It also doesn't show up in Devices on the Finders. Now, if I go to Disk Utility, I see the stick is logged there. The machine knows about it! Partition map is GUID, which should be fine. The stick has all permissions enabled. What am I missing??? Why can't I read this stick on other machines?
Well, OK, I realize that the stick is recognized, but not mounting on my older machines. In Disk Utility, the "Mount" button for that stick is greyed out. How do I get it mounted, and why shouldn't I be able to do so? Is this some funny formatting issue?
