Uppercase drive format required!
I just purchased Adobe Photoshop Elements 2021.
I am running Big Sur 11.2.3
I can down the disk image for installation.
When I click on the photoshop installer I get a threat warning that this installer will on install the installation files to an uppercase formatted drive.
OK so I can reformat an external drive to uppercase choice.
But the apple drive utility does not show.... UPPERCASE, FAT, EXFAT, only versions of APFS.
You probably need one of the 'Case Sensitive' options i.e. APFS (case sensitive)
Did you purchase Adobe Photoshop Elements 2021 directly from Adobe? If not, where?
directly on line about 2 weeks ago
Big Sur does not have uppercase on formatting option or Journaling.
Correct, APFS uses other data security features that are different than the journaling in HFS+. However, you can actually format in Big Sur using APFS (Case-sensitive)
If your drive is formatted that way, that would prevent the Adobe installer from working, as it states it cannot install on a volume that uses a case-sensitive file system. If you did standard APFS, that isn't case-sensitive, and the Adobe installer should work.
Can you upload a screenshot of the error you are getting with the Adobe installer?
Thank you for your help.
All is well now!
I am using TIME MACHINE for complete backups.
I do trust it for all backups.
Big Sur disk utility does not appear to have upper car only format, I tried all four,
However if you add a partition many other formats are included.
So I made a partition that is almost all of the drive, and went down the list.
Start in apple recovery mode "command R"..... erased the startup drive and made a partition for 95% of the drive ,,, then reinstalled Big Sur and all worked.
_____________________
I cannot send the stupid Adobe warning screen about requiring uppercase format,
It is not there anymore and the installation went smoothly.
Thanks again
