system prefs
KRR
OS 10.6.8
System prefs~desktopscreen, I added several folders some of which I want to remove. The minus sign is always greyed out.
How do I activate the minus sign in order to remove them?
KRR
-Did you try clicking one of the folders to select it? It should then activate the (-) button.
-Have you moved any of the folders since you added them?
