Reinstall Audio Midi Setup??
I deleted Audio Midi Setup accidentally and now have a problem with only getting sounds through iTunes and system alerts.
I have found the solution elsewhere online as being:
Open Audio MIDI Setup (/Applications/Utilities/), then check the Audio Output setting.
Change the Audio Output setting to 44100.0 Hz.
Quit Audio MIDI Setup.
How can I get Audio Midi Setup installed without a full reinstall of OSX? Or alternatively where can I download it to install?
Or does anyone know how I can solve the sound issue without it?
Sorry for waffling on.
Hello, you don't need to reinstall the OS in order to get Audio MIDI Setup back.
http://www.macworld.com/article/132243/2008/02/pacifist.html
Thanks, tried that, but optional install only allows the core apps such as iCal, Safari etc.
No sign of Audio Midi Setup?
