- Dec 31, 2008
I just drag the program to the trash, you can do a Spotlight search for anything else related to that program and trash that as well... Simple
You could try running Disc repair you'll find it in your Applications folder, Disk Utility, First Aid, Repair disk.
then uninstall it.
then uninstall it.
