Password HELP!!!
My G3 passwords are all lost! IS THERE ANYWAY TO GET EM BACK?
I can't install anything! No updates! Nada!
Please help......please?
Shane
Hi there and welcome !
do you mean your User Password ?
If so boot of the OS CD or DVD and Choose Reset Password from the Installer menu (or Utilities menu in Mac OS X 10.4 Tiger).
This will allow you to reset the main account or Admin password !
I'm trying to reset the master password. No GOOD!!!
I've tried a startup disk to reset but it doesnt seem to have worked.
I am an idiot it seems so bear with me.
Thanks
Hi there,
don't put yourself down ;-)
Computers have a way of making us all feel like that sometimes !!!
What version of OS X are you running ?
How many user accounts are on that Mac ?
Ver 10.3.9
Also are the passwords case sens?
I got a note book and I'm trying all combinations of what it can be for now. There's got to be a better way!!
Hi there,
passwords are case sensitive...
The Boot disk should work, I've never had it fail yet.
Give this a go ! Boot from the Disk holding down the c key
Regards
D
dick
So Ric,
do tell us how you insert all those sreen shots. I know the Command-Shift-3 and
Command-Shift-4 commands, but are just just dragging & drop into the message area?
dick
Hi dick,
You can add the images inline by pressing the "Insert Image" button...
You are then presented with a dialog box, where you need to enter the URL of the image...
There are various "Image Hosting" websites where you can set up an account, such as...
http://imageshack.us/ or http://photobucket.com/
...you need to 'link' to the image files... from a web server !
So once you had an account with one of these companies, you then do a screen grab...send it to your Image Hosting account and link to it here !
If you haven't got an Image host then you can also add the image as an attachment, see below.
If I see images added as attachments, I will change them to inline pics by adding them to my space...
Hope that helps !
