What is the simplest/correct way to install an OS-9 system folder on OS-10.4 Tiger
to allow installation of OS-9 applications to run in Classic? I have a Power Mac G4 MDD 1.25Ghz with 1 un-partioned hard drive. I DO NOT need to be able to boot in OS-9.
I do not have Tiger install discs. I do have original OS 9.0.4 discs from my Power Mac
G4 Gigibit, a CD of 9.1,9.2.1,9.2.2 updates downloaded from Apple, as well as a G4
iMac that has the needed OS-9 system folder installed. Am going blind reading forums for days with conflicting answers. The solution must be easier than the pursuit has been. Thanks.
