Kernel Panic Message + Booting Problems
Hi Everyone,
I'd really appreciate a little help with a problem I've been struggling with the last few days. I have a 24" iMac with 2.33 Ghz Intel Dual Core with 2 GB of RAM, and I'm running OS X 10.6.8.
A couple of days ago my computer crashed and I got the infamous kernel panic message ("you need to restart your computer..."). I can only boot my system up using safe mode. If I try to use my external drive or the installation disk that came with the computer I get the kernel panic message every time.
While in safe mode I've verified the disk, and there's nothing wrong with it apparently. I want to format everything, because it's been a long time, but this doesn't seem to be an option for me at the moment due to these other problems. Here's a copy of a part of the kernel panic message (which is a lot longer):
panic(cpu 1 caller 0x001A407F): Unresolved kernel trap (CPU 1, Type 14=page fault), registers:
CR0: 0x8001003b, CR2: 0x000000c0, CR3: 0x01248000, CR4: 0x000006e0
EAX: 0x25843438, EBX: 0x04199804, ECX: 0x00000001, EDX: 0x00000000
CR2: 0x000000c0, EBP: 0x25843468, ESI: 0x00000000, EDI: 0x00000040
EFL: 0x00010246, EIP: 0x3cee6b52, CS: 0x00000008, DS: 0x047e0010
Kernel loadable modules in backtrace (with dependencies):
com.apple.NVDAResman(4.3.8)@0x3ced3000
dependency: com.apple.iokit.IOPCIFamily(2.1)@0x35b6e000
dependency: com.apple.iokit.IONDRVSupport(1.4.4)@0x3bb39000
dependency: com.apple.iokit.IOGraphicsFamily(1.4.4)@0x35de3000
Anyways, I'd really appreciate someone else's take on this, because I'm kind of out of ideas at the moment!
Kernel Panics meant there is something serious wrong with your Mac. I would take it to an Apple Service Centre near you.
