Imac 21,5 Inch 2015 late, Not turning on.
Hello my name is Dylan
I got this problem my imac is not turning on.
what have i tried?
The 10 seconds joke with cable put it out and after 10 seconds back in, still nothing
New power supply, nothing happends
also the motherboard should give a light but no lights
i discovered that the motherboard has tapping shock waves,
i have search the problem trough my motherboard with a multi-meter, but every little part from top to bottom, it has shock waves,
so i tought maybe its a bad power supply but it is brand new? And you should et 2 beeps and atleast a light, but nothing,
i have tried to remove the hard drive completly but nothing.
What to do? I cant figure out wat it is And it is hurting my brain so much.
It sounds like a logic board issue, since you have replaced the power supply. Yes, it could be a bad replacement power supply as well. But, without being able to see the iMac in person, it can be very difficult to diagnose.
Uhm, i have 2 things discovered,
i changed the 3V battery in the back,
And motherboard has power trough it but its not that much,
any tips to find out if the motherboard is something wrong?
i realy hope i can fix this because it costed me allot this imac so,
any tips ? I can check on? Of look for?
if need any pictures feel free to ask i will respond with the pictures,
Since Apple doesn't publish schematics and component-level testing information, the only way to determine if the logic board is bad is to replace it.
Sorry, I don't have any additional information that may be helpful.
