HP /Leopard... help!
I installed Leopard a couple months ago and ever since then my HP Deskjet 5700 is not working. When it finds the printer and I select it to print it says "searching for new drivers" but never finds any. I know that the new HP drivers were automatically supposed to be installed with Leopard, and I cannot find new ones for Leopard online anywhere. How do I fix this problem?
What that is telling you is that you need to re-install your printer drivers. Probably you might have unchecked that option in your Leopard installation or the driver you currently have is outdated. Go to the HP home page and download the driver for your printer. Once you install it, everything should be fine. The Leopard installation disk also contains those drivers. You can try to install just that one item.
