Help
i dont know if this is the right spot but ...I have an IMac and today when i woke up I found my screen turn to a "negative Look" so now eveything is in that effect even when I watch videos its in " negative effect" this is frustrating . How do I fix this?
Try this:
1. Click on Apple in menubar
2. Select System Preferences
3. Click Universal Access
4. On the Seeing tab, in the Display section click the radio button next to Black on white
When you see the "negative effect" it is probably set on White on black.
Let us know if this doesn't fix it.
hey Cory thank you so much I was able to fix this problem with what you said. You prob saved my hrs upon hrs of frustration..... I knew it was prob something as simple as that to...thank you again
