Okay, first my Powerbook (12") hard drive crashed. This happened a couple months ago, but I was able to wipe everything and reinstall, no problems.
So this time, before I could re-install, a lovely guest at my apartment spilled beer onto the side of the slot loading drive and failed to tell me. When I noticed this over 48 hours later, the beer and hardened on the fuzzy portion of the optical slot loading drive (where the disc slides in).
I tried using Q-Tips to clean this off, didn't help. One of my install discs is in there, and it will not eject due to the sticky and hard nature of the fuzzy part of the slot-loading drive.
I have looked at manuals for getting the optical drive out and it looks totally scary.
Is there another way I can fix the drive so I can load and eject discs? Or, alternately, could I use a USB CD-ROM drive to install that way? I am at a loss.
Thank you in advance!
-Nichole
-Nichole
