Help me chose please!!!
Hi guys
Im in between two models of macbook pro
13 inch Muhp2 2019 Vs 15 inch mptr2 2017
And if the 15 inch is stronger, is it so better that worth spending a couple hundred dollars more on it?
appreciate your opinion thanks
It would come down to a few things:
-What is your normal usage of your computer?
-What is your budget?
-Does the screen size matter?
-Apple normally makes Macs obsolete (non-repairable, hard to find parts) after 5 years.
