Hello....Im *very* new to Mac and in the process of swapping from this dreaded PC to the glorious world of apple! (thank goodness I still have it here to help me recover from my dilemma).
It was all working perfectly (yes its never had a problem in the 2 weeks Ive been experimenting with it!), but then I had a warning about low disk space.....I tried deleting some d/l programs etc & then emptying the trash, but thats when it hung & I had to reboot.
She's never recovered since
Trouble is I now have the white screen with apple logo & the spinning pinwheel @ the bottom when I start it up. No start up sound or anything. I looked at the forums & managed to get the damn thing to eventually load the original OSX software CD ( 10.3 Panther) but if I go thru the process of trying to reinstall the OS it wont let me as my HDD doesnt have enough space.
Im sure the problem is with the HDD or something, but is there any way I can get into it & delete some stuff without having to format it & loose all the stuff I have transfered over?
What I have done so far:
* Hard reset with pwr off for a good 8hrs while @ work
* Pressed that button near the backup battery once.
* Removed & replaced the battery
* Removed the HDD connection to bootup
* Removed all external devices/peripherals
I have run out of options!
All I can remember is its got about 7?? something RAM, a 40Gb hDD & its a 450Mhz processor I think....but I cant get in to confirm any of that.
Id really appreciate any help offered.
Thank you
Nigel
Melbourne, Australia
Thank you
Nigel
