- Aug 3, 2011
Hi Guys
I am trying to format the above using the instructions at this link http://www.seagate.com/ww/v/index.jsp?vgnextoid=da3bd85104b51210VgnVCM1000001a48090aRCRD
Unfortunately the laptop is quite old and so far after follwing the
instructions and letting it run (36 hours each time) I keep getting a
failed error "Volume Erase failed with error, the underlying task
reported failure on exit". Can anyone advise whether there is an easier
way to format this model?
thank you and please let me know if I haven't been clear on anything
Thanks
NoelS
Thanks
NoelS
