Final Cut Pro Shutting Down On Me
Every time I try to open Final Cut Pro it shuts down on me and leaves me with this message...
The Application Final Cut Pro quit unexpectedly.
Mac OS X and other applications are not affected.
Click Reopen to open the application again. Click Report to see more details or send a report to Apple.
It was working fine a few days ago. What happened and how do I fix it?
Thanks!
-James
Model Name: MacBook Pro 15"
Model Identifier: MacBookPro2,2
Processor Name: Intel Core 2 Duo
Processor Speed: 2.33 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache (per processor): 4 MB
Memory: 2 GB
Bus Speed: 667 MHz
is this what you needed?
how do you do that?
To repair permissions:
Open Disk Utility, located at /Applications/Utilities/Disk Utility
Select your startup disk on the left of the Disk Utility window
Select "First Aid" from the tabs if not already selected
Click the "Repair Disk Permissions" button
