Ive tried that disk utility when I click on erase on the popup erase is grayed outIve tried all the methods I can find nothing works . starting up from the cd holding the c key the computer just starts.
These are old machines that are that are probably already running the newest OS they are capable of running.It's not clear why if if you're going to scap them, you need to install a new OS. You should be able to connect them by ethernet or USB, boot up into one and use it to reformat/erase the other with Disk Utility or DiskWarrior.
