Boot Up Problems! Please Help!
Few days ago my Powerbook was running very slow so I decided to reboot it. Big mistake, after restarting it, it apparently froze on the white screen with the gray apple. It just sits there and does nothing. I tried booting off of the restore disk to do an "Archive and Restore" but there isn't even an option to restore to on the menu. I ran the Hardware test and got this error from Mass Storage: 2STF/4/3:ATA-100ata-6-Master
Any ideas??????
Hi there and welcome !
First try and boot into single user mode...
You can start up the Mac and hold down the command + s keys...untill you get to a "prompt"
Then type
/sbin/fsck -fy
then press return
This will manually run FSCK...then once it has finished (it may take a while) type
reboot
and press return.
Your Mac should now boot up successfully.
Give this a go first...
Then type
/sbin/fsck -fy
then press return
reboot
and press return.
I have tried to boot in safe mode and single user mode and neither has worked. I may be doing something wrong, I turn it on and immediately hold down the command and s keys but nothing happens. I just get the white screen with the apple. Am I doing something wrong? Should I push them at the same time? Or command then s? How long should it take to bring up the prompt? Thanks for your help!
...try this.
Turn the computer off...then with your left thumb hold down the command key (on the left side of the keyboard)...while keeping the command key held down, now press and hold down the s key...keeping these both depressed, now with your right hand turn on the Mac. (keep both keys pressed till the black sceen comes up with white text !)
Give that a go, and let us know !
...try this.
Thanks, I'll try that as soon as I get home from work.
Another thing that seemed odd, when I booted off of the restore disk and came to the screen where you select where you want to install the OS to and you click on the harddrive icon, there was no icon there.
...try this.
No luck, did exactly how you said and held it down for a good 5 minutes and still nothing.
Any ideas???
Hi there,
it sounds as though the drive could have died...
Try booting off the install disk again, and seeing if it will allow you to run disk utilities-->repair disk.
I don't think it will, but worth a go.
You weren't getting the "Archive Option" because it couldn't see a disk to install onto...
Do you have Apple Care ?
If not it might be trip to Maplin's for a new hard drive.
Hi there,
I can see the Hardrive icon through Disk Utility but it won't let me repair it, the only option I have when I highlight the Harddrive icon is Verify Disk and when I do that it tells me it needs repaired but won't let me repair it.
Unfortunately I don't have AppleCare so looks like I might need a new drive. :(
I just wish there was some way to recover all my music and pictures.
Hi there,
it's difficult to say for certain but I would try using DiskWarrior, to see if it could fix it...it fixes things that the normal Disk Utility can't !
...if not then try DataRescue to retreive your files.
Sorry, but they both cost ! There's nothing shareware/freeware that does the job like these !
mine just froze on the same screen- i can't run repair discs because there is a dvd in there, and i have no idea how to get it out! have you made any progress? if so, yould you help me?
Go
To get the DVD out...try:
Restart and immediately hold the mouse button down. Keep holding it and the disc tray should eject during startup.
