Air turn BT106
My Air-Turn BT-106 device has worked fine for several months but all of the sudden the right pedal doesn't function anymore. I have tried all of the usual usual techniques (restart, re-pair, etc) but nothing seems to work. Can you help?
It sounds from your description that you have done all the recommended troubleshooting steps. Is it just the right pedal that isn't working? If so, there may be a hardware issue with the device, and it may be best to contact AirTurn directly.
