USB Drive is Read-Only on Mac
I have a MacBook Pro(13.3.1 (22E261)) that has a USB Drive(Seagate Model SRD00F1). I have the NTFS Paragon Driver installed. This was working fine. Now it is read-only. I have tried uninstalling and reinstalling the Paragon Software driver. It still is just read-only. It seems to be mounted fine in Disk Utility and System Information. I can see all of the files on the drive. I can also see the files fine when I attach them to a Windows machine.
I assume you are using either the Seagate Paragon Drive or version 15 of Microsoft NTFS for Mac by Paragon Software?
I personally haven't used it, but maybe another member here who has will chime in. Honestly, it may be best to contact their support, as they would have the best troubleshooting to try.
