Screen not starting
I have a 2013 Mac pro running mac OS Montery and on start up the monitor often will not light up. If however I plug in a second monitor, then unplug the first monitor and plug back in it will light up and work normally. Any ideas please. TIA
Sounds like there may be an issue with the monitor itself or the graphics card. have you tried using the second monitor only in the same connection port?
