MacBook won't start! Help
So about 2013 I boughta 13book Pro. It's worked fine up untill now.One day my computer froze for no reason so I powered it down manually.
When I tried to start it back up, I get this like block or caution sign thing. Then I tried again and got thise Missing Folder icon. It was very strange I tried safe boot and that worked. Then I tried and again and now safe boot doesnt work. Im starting to run out of options. Is this thing done for? I also tried doing the option command p r thing. That also didnt work. Any help?
Sounds like you've done some problem solving & research & you've tried some important steps but what happens if you boot up holding the Opt key or the X key?
Can you see an Operating System there to select?
Does sound like your internal drive might have failed ...
