What inputs are on your TV? If its a newish HD ready TV you could just get a standard DVI to HDMI cable - Apple store link
or you can use the DVI to Composite adapter if your TV doesn't have HDMI ports - Apple store link
The HDMI option gives much better quality, if your TV has a standard D-SUB VGA port then you can use the DVI to VGA adapter that comes with the MacBook Pro and a standard VGA cable (which is the way I do it as my TV doesnt have HDMI).
