Global Command For Closing Out Everything Running ?
Is there a GLOBAL Command, somewhere, that will close out
all of the running apps/programs, etc. simply ?
Thanks,
Bob
1. Go to Applications and open Automator.
2. Click New Document, click Application.
3. Scroll down to Quit all applications and double click.
4. Save to desktop as something like Quit_All.app
Then just double click the icon when you want to quit all open apps.
Can't seem to get to work.
What might I be doing wrong, please, as usual ?
I have a bunch of icons in the Dock, many of which have the dot underneath them.
My understanding is that this means they are running.
I created the Automator with the Quit All Applications (selected and moved to right hand pane.)
Then did a SAVE. Would like to Quit their running, all of them, with a simple click on the desktop icon for this app that I now have.
When i click on the desktop icon for it, nothing opens or changes.
Those dots are still there.
There is however a spinning gear icon in the upper bar.
Will try to show it below. [it says: 0% completed (Quit All Applications)]
What am I likely not doing, or doing incorrectly ?
Thanks, Bob
OK, earlier I did it successfully on my Mac Book Air. But for my Mac Mini, I was skipping part of one important piece: double click. I was forgetting to do that. But I then followed the instructions more closely, and it works.
I cannot seem to replicate your problem, I will look in a little more detail.
As Honestone says it does need a double click on the icon.
As I stated, I followed the original instructions to the letter on my Mac Book Air, and it worked right away. But on my Mac Min i, the first time I tried, I did not double click where it says "Quit all applications". But after reading the op's post, I tried it again, and this time followed the instructions to the letter. It then worked.
