it doesnt do anything, i have checked all the cables and even opened it up and checked it against my currently working, identical machine. it all started after I replaced the hard drive in it and installed the boot disk, it ran fine for about an hour and then froze, when i reset it, it gave me the folder with the question mark. I was told that it was just a problem with the bios and that i should reset the pmu, after that the computer will do nothing, i dont get any output to the monitor and the button which usually stays lit after you turn it on goes off right away. About 30 seconds later the fan goes crazy and sounds like its going to take off. I'm really getting frustrated with it.
Thank You for responding.
