I just downloaded an evil genius, and I moved to play on the screen also looked kind of "broken" in the main menu and the whole way through the toolbar in the main game.i AM you are so far But what is meant to replace the file. exe there 2 of em autorun.exe and setup.exe are the only two exe files, so I just put the patch I downloaded the file with them or should I remove the other two something because someone said I had to replace the original import, but do not know how.
