- Jul 31, 2010
I have been trying, to find a one click solution to connect - or disconnect Ethernet, similar to the feature available to connect / disconnect "Airport".
At the moment I am using an Automator script, which however is not only slow, but will not work 4 out of ten times (cursor just hangs during the operation).
The best solution would probably be an AppleScript, but despite consulting various sites on the Internet, I could not manage, to work out the respective mnemonics required, to write such a script.
In order to connect manually, my current procedure is:
System Preferences
Network
Ethernet
Configure IPv4
using DHCP
Apply
To disconnect:
System Preferences
Network
Ethernet
Configure IPv4
Off
Apply
For either of the 2 procedures I would need some assistance to write a Script.
My system configuration:
MacBook Pro 17", 2.66GHz, 4GB Ram
Mac OSX 10.6.4
Any solution, even other than an AppleScript, would be greatly appreciated. Thanks in advance, Vic
System Preferences
Network
Ethernet
Configure IPv4
using DHCP
Apply
To disconnect:
System Preferences
Network
Ethernet
Configure IPv4
Off
Apply
Mac OSX 10.6.4
