Another spilled water question.
My daughter spilled water on her Mac Air and it seem the only place it may have breached the machine was via power port...
Unfortunately she did try to start it again...
Left turned off after this and applied hair dryer for a few hours...since then its been a little clunky fan running loud performance lag.
Any tips or advice as to what to do next apprecaited.
Unfortunately, the best suggestion is to have it checked out and repaired by an Apple Authorized Service Provider, as that is the best way to ensure it is safe to use and back to full operating spec.
