airport card installation
I would like to know how to install a airport card in a imac. the mac sight gives instructions but I was wondering is there is any video on this procedure or more info. Thanks Tim
I depends on your Mac, but if its one that is meant to be installed by the user then its very straight forward.
it is the one for users to install, I was just wondering if there were pictures or video of the installation
No, nothing like that here.
You pop the panel open, move the ariel connector out of the way, slide in the card (if its the right one it will be a snug fit) plug in the ariel. Restart and you're good to go...
It depends of the model, you haven't given me much to go on here, there has been 10 years of iMacs which have AirPort cards.
