No ethernet on 27" iMac (Late 2009) has ne baffled. Need expert advice.
3.06GHz Core 2 Duo
A1312 \ EMC 2309 \ MB952LL/A
PROBLEM:
  • This iMac won't recognize that an Ethernet cable and says it is unplugged when it is indeed plugged in.
STEPS TAKEN:
  • Passes Apple Hardware Test with flying colors.
  • Reset PRAM, SMC
  • Tried different cables and modems.
  • Fresh copy of Snow Leopard installed.
  • Inspected Ethernet port for damage.
  • Inspected logic board for blown capacitors, ect...
  • Repeatedly hitting it with a hammer. :eek:
I know the obvious answer is to replace the logic board, but I'm trying to figure out where the failure is so I can possibly resolder and/or replace that component. The jack looks fine. :confused:
The only clue I have is that it hangs on the hardware test at the "Ethernet Controller (test #13) - PHY 10 Loopback Test" for about 2 minutes and then it passes.
Some expert advice would be most welcome. :)
