SDK package /Developer/SDKs/MacOSX10.4u.sdk does not exist
Hi there and welcome,
have you had a look in the folder to see if the SDK is there ?
Let us know if it is there or not...
It sounds like Xcode may not have installed correctly...you may need to reinstall.
Hi Ric
Thanks for that, I had tried reinstalling a few times but this added the MacOSX1.4.Universal.pkg for the xcode tools, and it worked perfectly
Cheers
James
No problem !
You'll have to let us know what you make !
iPhone SDK Question 1
