Network/WiFi Problem
I have an IMac27 late 2013 (I know, it's antique). I also have an HP 700 series Win based box, same vintage, (it's antique too). The HP was the primary machine until recently. It seems to have lost WiFi. 2 smart TV's, an IPad, an IPhone6 and other stuff won't connect wirelessly any more. They all come up with 'no internet, no server, etc.' So... why can't I get the Mac to use it's WiFi to connect anything? The Mac will only 'connect' to the Win based machine, or anything, over the network when you stand on your left foot, facing north and the sun is in full eclipse...or some such. It has always been like that, since I bought them both, the Mac connects to nothing unless it feels like it. I need the Mac's WiFi capabilities until I decide either to repair or trash the HP, but I can't get any wireless connection to anything. It says WiFi is turned on. The TV's are passworded to the modem/router, that's all the Win box ever needed. The Mac is hardwired (cat5) to the router. The Mac is the only powered-up box on the network at the moment. Still the same problems.
I'm at a bit of a loss... Any help greatly appreciated.
I am running an iMac (21.5-inch, Late 2009), so yours is a powerhouse! ;)
A few questions:
-Which version of OS X/macOS?
-Has it ever reliably connected to Wi-Fi?
-You stated it is hard-wired to the router as well...can it reach the Internet via Ethernet? Is there a reason you have it hard-wired too?
-You stated "2 smart TV's, an IPad, an IPhone6 and other stuff won't connect wirelessly any more." So nothing connects to Wi-Fi any longer?
If nothing connects, I would suggest the following:
-Disconnect the iMac's Ethernet cable
-Power cycle the router
-Make sure Wi-Fi is at the top of the Service Order in the Network preference pane
OK, thanks.
It is sounding more like an issue with your modem/router. Have you tried power cycling it - unplug it from AC for 15 seconds, plug it back in and wait for it to finish initializing.
Also, I prefer Ethernet over Wi-Fi on my Macs. I turn off Wi-Fi on them, and simply use Ethernet cables. Of course, your router would need enough LAN ports for each device connected that way - i.e. the PC and the iMac.
What brand/model is the router?
Back
